V1 Clutch pipe into trans
WA08TC
WA08TC
Can someone post pics of how the clutch pipe looks/is routed to the outside of the trans. About to mount up the motor/trans. F35
I can’t post any pix but the steel tube built in your goblin just kind of hangs out into space below the fuse box and above the trans. There is an elbow that goes on the output of the trans that points due left to mate up to the steel pipe end. Post a pic of the pipe sticking out of the trans! There is a seal that can go missing. Sadly the seal is not sold seperately! But you can buy just the Throw out bearing pipe for an F35 and swap just he seal onto your existing pipe. (Provided that pipe is not damaged. I’ve seen two posts of builders that did the same as me. Later I found their pix showing the same problem, missing seal! ) I found this out after dropping the trans to replace the pipe and the T/O bearing! Popping that new seal off a new pipe and onto the existing pipe would take a minute, dropping the transmission takes hours!
#1. file:///var/mobile/Library/SMS/Attachments/99/09/2B92E61D-B96B-45F6-8103-4CCF8914A1A5/71510308971__EEF32E9B-0622-4E9B-9B0B-205C16446E7F.HEIC without seal. #2 file:///var/mobile/Library/SMS/Attachments/ea/10/CD5511EF-BC4D-4123-91C5-DCDB3CD819AA/71510312720__4E61391D-C7FE-4847-929B-9E3F41B73E62.HEIC With seal!!
