SwerveMonkey
- SwerveMonkey Well-Known Member
I've been heavily leaning on and learning from Bar-Air's posts back in the day when he turbocharged a 2.4 ecotec....
I was trying to confirm on my own but have only gotten so far with google and forum searches ( here and elsewhere )
but i really want to ask as confirmation before i do something potentially stupid...
Is it really just that simple to drill a hole out in the engine block for the turbo oil return line to go into??
like in the image here at back of the engine, red circle above the oil pan...
I'm seeing that the Z54 I bought from another forum member here is by default compatible only with the LNF/LHU turbo charger oil drain flange/tubing... but the end point is simply an o-ring'd spout...
I don't want to assume that it simple squeezes into an appropriately sized drilled hole, wouldn't the pressure (both oil in tube and volume in crankcase ) force the tube out of the hole if it just secured with an o-ring??
maybe i am being too cautious before i go beyond the point of no return... thanks in advanced for any guidance you have ^_^
