V1 Engine alternator 6 rib pulley
Zoom Zoom
Zoom Zoom
Has any body bought the ZZ PERFORMANCE crate engine LDF and it come with 6 rib harmonic balancer so I need to buy a 6 rib pulley for my alternator, If anyone has bought one already, Can you tell me where you bought yours from and what size. Would be greatly appreciated.
Thank You
TheNuker
I double checked mine and it is also a 6 rib. I just bought a brand new alternator which is factory at 5 rib. I'm not sure it matters as I see that the ATI harmonic balancer are 8 rib. So unless everyone that uses one of those is changing at minimum idler pully and alternator, and for some cars also AC and SC pulley what are they doing?
Nuker-
Zoom Zoom
My Harmonic
Balancer is 6 rib and the idler pulley is fatter as well for a 6 rib belt, just need to get alternator 6 rib pulley, or just run it with
Zoom Zoom
Nuker-
I bought the belt Lonny suggested for the 5 rib, but with this being 6 and a bigger idler, does your belt seem to tight
Zoom Zoom
Yeah they are easy to find just don’t know what size shaft to get could call summit or one of them and tell them what we need and they should be able to tell us which one.
Will let you know if I find one but I’m cleaning stuff to put on my new engine,
So we need a 6 rib belt 1-2 inch longer
Zoom Zoom
Okay I found one on amazon a lot cheaper than jegs for 13.77 will just have to paint it black. Now the fan belt I measured from one mark all the way around and it’s 35 that’s what the wrapper stated also. So I figured 36 would do it but the one I pull up on amazon looks way to long
TheNuker
Can you send me a link to that pulley? Thanks! And yeah I'll try fitting the belt when I get it back. I guess its nice to have 6 rib vs 5 bit more grip :D
Nuker-
Zoom Zoom
I no you don’t want it slipping on you, we need more grip with the bigger turbo. My Roush has the 6 rib super charger with 675 ponies . I don’t really know how to send a link but I’ll see what I can do
Zoom Zoom
Do you see what I see, Exact fit
6 Rib Alternator Pulley,
Will powder coat BLACK
