V1 Footwell cover installation
You could trim it. The hood will cover that part.
Oh that’s not an interference. It’s not designed to drop on top, you tilt the cover (passenger side up slightly) to tuck the motor into the cavity in the footwell cover, then set the passenger side down.
Heck, you could even just pull that side out and push it down over the motor.
You’ll also more than likely have to pull the sides out anyways to line them up with the rails. Use coated clamps/vice grips to hold it against the rail as you drill them together.
Yes, mine is the same. I cut a fairly hefty portion away to make it drop in. It doesn't matter because the hood covers it.
SmsDetroit
Mine hits bad and I even replaces the mount with one that Lonny sent me and it still hits. I walked away from it this spring and haven’t looked at it since
