Ground Clearance - City Goblin
bradr
Does anyone know the ground clearance for a city goblin (assuming stock wheels and a standard setup)? I ask because I have a mid rise platform lift that I would like to be able to use for the build and park the Goblin on top of. The highest point on the lift is 5". Thanks!
That's just for the back. The front is a bit of a different story. For a variety of reasons, I don't have my front control arms level like they should be. They're higher in the middle than the tie rod end. My ground clearance to the radiator bracket is 6-1/2". If I had to guess, it's probably more than 1" higher than it should be.
It will be a tight fit if you go with the stock height.
