V1 Inspecting my obviously modified donor and making pre-kit modifications
ARabidNull
ARabidNull
I originally planned on ordering my kit two months ago, but reality has a way of ignoring your expectations and going on with its own plan. With a more critical look, I'm actually going to be ordering a kit sometime between September 2021 and February 2022. However, I've already purchased a donor.
The only time I've driven a stick was in 1995 for a total of about six hours. So I purchased a 2006 Supercharged Cobalt SS a few months ago and started practicing. Since then I've noticed that it's been modified. ZZPerformance engine mount(s), custom exhaust header, who knows what else. My plan is to take stock of the current state of the engine/transmission/tune and possibly make some (cheaper/easier) modifications as appropriate.
I've been a "car guy" for a whole year and a half and a computer programmer by trade so I'm particularly interested in tuning and finding out if (and how) my donor has been tuned but I'd also like any advice I can get to help me figure out what changes have been made.
socaljeff3798
The lead time on kits right now is about 3 months!...Yes they are that busy. And I suspect it may get longer. You might want to keep that in mind for your time line.
The physical stuff is easy enough to spot and you can always send a photo to ask the forum. The programming stuff will require someone with HP Tuners to determine what is changed from stock. :D
ARabidNull
Thanks, I'll keep that in mind. My timeframe is dictated by my current task list more than anything. My wife and I moved from a house with no yard to a property with a few acres that need work so until my to-do list is short enough, I don't want to add to it. I'll adjust my order with the lead time in mind.
With HP Tuners, you can download and inspect your tune, as long as it isn't locked by a previous tuner.
Does your donor already have an aftermarket wideband gauge installed? (AFR gauge = Air Fuel Ratio)
If not, you will need to add one in order to do tuning.
Ya. Post a few pics of the engine compartment. We can spot several things. Tuning, HP tuners is the way to go. I think with your computer background, you’ll have a lot of fun with it.
ARabidNull
Here are a few pics. I'll look into HP Tuners.
ARabidNull
I don't think it does, I'll put it on the list of things to figure out/get.
I can tell I'm getting old. I find it interesting what has been done to these cars by the younger generations. Too be honest, I did things much like this, so I'm not dogging on them.
ZZP engine mount.
Looks like the supercharger has been opened for some reason, the black plate is not normal.
Red loom on random wires
plate over the fusebox, why?
CAI
ARabidNull
Good news! I found an AEM air/fuel ratio gauge crammed into the little bin on the driver's side that also has the trunk release button.
Bad news! It doesn't work. The photo is from the car running.
