V1 Part 6 Organizing the Main Harness 3
Are you talking, where do they land on the goblin? Should be just under the fuse box
50911
Traé
In part 5 you strip the headlight harness and extend some ground wires. Part 6 states You pull one wire for the intercooler water pump, add a ground lug and solder all of the others together. The fuse box ground should be in the bundle that you extended.
I remember helping you out on Facebook. I kept a key on power wire for the “intercooler water pump” and ground as stated in the videos for TC donors coiled up for future use. It will not be used on the supercharged version as our car has a plug for the pump in the engine harness that does not get modified.
J
I rewatched the previous video twice and didn’t miss anything. Out of the four grounds that were extended, one was pulled towards the bcm (not used since it’s SC), two to the tail lights, and the last to the license plate light.
I bundled the abs lug, fuel pump, and coolant tank grounds. I still don’t know what the fuse box ground is.
I can take another look at it tomorrow with some fresh eyes.
Markm
This should be what you’re looking for. Connector c3 terminal f2
