comegetjoe
- comegetjoe Goblin Guru
Are these the same lines? I see the line fitting size and how the bigger one with the hook goes into the booster block, but the other one does not reach the Tee, by a good amount. The two lines are the same shape.
Did I get the wrong line or am I missing something?
Booster block with the large fitting, under the booster block and up the proportioning valve, over the proportioning valve, through the proportioning valve and out the other side and then to the Tee, correct
