- JBuild Member
Looks like the rear main seal is bad so I need to pull the transmission to change it.
Does anyone know if it's possible to support the motor and just remove the trans?
Seems like the 3 transmission variants are about the same size so I would imagine if one makes it out they all would. If not I'm hoping I can just leave everything hooked up and lift the frame.
