Bigfoot Goblin
Old hubs from the donor with XXX,XXX miles on them? "Hello Rockauto, I'd like to place an order..."
That's exactly what i am thinking now... initially i considered scrounging through my left over donor bolts, but realized that was a DEATHLY bad idea.Old hubs from the donor with XXX,XXX miles on them? "Hello Rockauto, I'd like to place an order..."![]()
Check for brake fluid in the brake booster and replace the booster if there’s fluid in it
I recommend adding the proportioning valve first. I also added a vacuum regulator so I can adjust how much boost the brakes get.
If you opt to stick with the donor setup - and you find the booster is the issue - I have a functional donor brake booster that I will not be using.![]()
Lesson Learned:
Non-SS brake boosters do not have the same "bore" diameter opening as the SS boosters
SS master cylinder insert diameter is smaller than the Non-SS versions
I noticed that the two top ports looked different when inspecting the part on arrival...Where did that slotted disc come from? I've never seen one of those pieces. Was it in the MC reservoir? In one of the fluid source inlets?
