- ctuinstra Goblin Guru
In some of my posts in the past, we commented about an issue with the touchy throttle. We've had an issue with any kind of bump in the road causing my foot to bounce a bit on the throttle and constantly blipping the throttle. At times it was difficult to drive, such as up my gravel driveway that is plagued with wash-boarding at times. I was looking for ways to add a stiffer spring to some type of damper to the throttle. We have modified the throttle response under low load conditions and that has helped but not eliminated the issue.
Well as it turns out while dealing with suspension issues, one of the things we realized is that we had somehow increased (and left) the compression dampening on the front Q1 shocks. This made them so stiff the entire frame of the car bounced on some bad road causing our body, leg, and foot to bounce on the throttle. After softening the compression (to about 3-5 clicks in from all the way out), I unexpectedly noticed one day that I was no longer having any throttle bounce; not even up the bumpy driveway! Almost never! We can drive it smooth as we want. The same road that I used to hate taking was no longer an issue. I cannot believe the difference it has made. We may tighten it up just a tad, but it's a great start.
As far as I'm concerned, I'm no longer looking for a fix for the throttle. Unless we HAVE to change the suspension for track or something. I'm happy with the way it is.
What are yours set to?
