V1 Turning off unwanted dash lights?
Amack1970
Amack1970
I've heard there's a thread out there with instructions on how and what to snip inside the cluster. I'd like to eliminate the abs, traction control and srs lights. Oh and the e brake light too
Amack1970
I just severed those leads. The low pressure light is on, but the others are gone. Did I not get one all the way?
They are hard to cut all the way through. You might not have cut it completely. You might try using a meter to ohm out the connection between the two closest through holes.
Check with an ohm meter between the two holes marked in red. It should be an open circuit.
8950
