V1 Unknown connector
Lndshrk Steve
Lndshrk Steve
Hi Guys. Just finishing up thinning out the body harness. Have one connector left. I'm sure I missed something, but if I can cut this out I'd rather not have it hanging around. Four wires: one black (gnd), one gray, two green with white stripe. I had to rent a space to break down my donor so I didn't label as well as I should have. Thanks for any help.
BTW it is about it's about 6 feet from the ECM/fuse box.
What connectors are nearest to that 4 prong connector?
It helps us. Also, moding your signature helps too. Link in my signature.
5 speed cars have the automatic transmission shifter plug too.
Lndshrk Steve
Well . . . . One of the wires from this connector (Dark green w/white stripe) is at, was at the Body to Dash connector B10, Key Lock Actuator. Do I need to solder this back on and find the other end or is this just used for the Automatics?
Lndshrk Steve
I'm just stuck. If this has to get added back in I have to UNDO some of the taping . . . but I don't know which. There are just so many variables that can't be addressed in a video . . . .
Lndshrk Steve
That's the plug and those are the wires. Thanks. Mine ran to Body to Dash connector B10, Key Lock Actuator. I just sure hope it runs without it . . . and I wouldn't know where to wire it to if it needed it. Thanks again. I'm just being nervous.
Lndshrk Steve
That makes me feel better because I don't have that on my ignition. But I misplaced my keys . . . and that's going to be a whole new problem, when I get to it. Thanks!
I'm pretty sure that would go to the solenoid/lock wires in the first picture here;
2005-2010 CHEVY COBALT IGNITION LOCK CYLINDER SWITCH ASSEMBLY W/KEYS OEM ILA105 | eBay
If you ignition barrel doesn't have that or you can remove it I would cut out the connector. It'd there to keep you from removing the key unless in Park.
I zip tied that plunger on my build because it was faulty. A manual car should not need it or the transmission shift lock solenoid connector.
Yes no key is a little bit of a problem. Either the car will have to go to a dealer or a mobile locksmith will have to come to you.
It might work to use a Tech2 clone but I've never tried it with programming a module.
