Where did you buy that? links
Gsd autos mn
Active Member
Gsd autos mn
I just started buying items for my build, I went and found as many links from our members threads as I could. Post a reply and edit it as you go, we will know what works and where to get it.
https://m.cabletiesandmore.com/prod...le-ties-50-lb-test-100-pack-all-one-color-302
Colored zip ties
https://www.eastwood.com/ew-radiator-black-12oz-satin-finish.html
Radiator Black
10x HPS 5/16"-25/64" (8mm-10mm) Stainless Steel Fuel Injection Hose Clamp SAE 9
https://www.amazon.com/dp/B07369QWD1/ref=cm_sw_r_cp_api_i_xkeDCb6DR5V28
8-10mm Gear clamps
GRIP (GRAND RAPIDS INDUSTRIAL) Grip 20 pc Wire Bore Brush Set https://www.amazon.com/dp/B01NB04QWL/ref=cm_sw_r_cp_api_i_MpQECbJNRW0FN
https://quote.thmotorsports.com/16814/7FE5CB13C5556522CF214069792C4D6B5DD6C3F7F31A229EE7BF1388369A
Stage 2 clutch and fly wheel with discount
https://thmotorsports.com/4256-south-bend-clutch?CId=0&MId=4256&OS=True&PF=None&SMIds=4256&PFC.Sort=Position&PFC.PageNumber=1&V.Year=0&V.Make=0&V.Model=0&V.SU=false&V.Seo=False&PageType=Manufacturer Results&IsManufacturerPageRequested=True&IsRootCategoryPageRequested=False
http://www.crateenginedepot.com/Cobalt-HHR-LNF-Clutch-Kit-24239996K-P17757.aspx
GM clutch kit
https://www.skunkwurx.co/ariel-atom-3-5-rear-stop-tail-led-lights-with-clear-lens.html
Atom tail lights
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/201909901640
59" carbon wing NRG
https://www.summitracing.com/parts/..._SMlnGuvn9yz1fjLwl4g45nSSM2f-u5Of8AaAusAEALw_
Seat brackets tall
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/162891921129
Braum Venom seats
You can get cheaper if you buy from sellers website
mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F183233170969
Wire loom
https://www.jegs.com/p/Vibrant-Perf...400-Flexible-Reflective-Wrap/3284154/10002/-1
Heat shield
https://www.bcracing-na.com/secure/cart?prodid=1280
Rear coils from BC
https://www.aa-mfg.com/
Chassis weld tabs
https://www.mcmaster.com/catalog/125/152
Brake fluid hose tygon
https://www.performanceplustire.com/staggered/
Staggered wheel package
https://www.shopcwo.com/c-1-wheels.html#!year=2009||make=CHEVROLET||model=COBALT||submodel=LT||bolt_pattern=5x110
5x110 wheels
http://www.frozenboost.com/liquid-air-adapter/remote-radiator-filler-cap-p-1064.html
Remote filler
https://www.crutchfield.com/S-Xdacc...XNbrc63XKFnF3PUA5razag3BO4Huo2PcaAhalEALw_wcB
Blue tooth radio w/amp inputs
https://www.westmarine.com/buy/fusion--ms-ra55-compact-marine-stereo-with-bluetooth--17816166?mrkgcl=481&mrkgadid=3076578767&cm_mmc=PS-_-Google-_-GSC>NonB>Product%20Type-_-17816166&product_id=17816166&adpos=1o8&creative=108421552444&device=m&matchtype=&network=g&gclid=Cj0KCQiAh9njBRCYARIsALJhQkGwR8qIi2fQSLpGSy3bIc3On8ODeCqL04gA3t5oA0BnDbsNOyBl_OkaAh7iEALw_wcB
Marine blue tooth radio no amp inputs
https://www.amazon.com/Clarion-XC24...ocphy=9019670&hvtargid=pla-437276819038&psc=1
Clarion mini amp
https://www.sonicelectronix.com/item_94427_Soundstream-MR4.1400D.html
Strong 4 channel low heat amp
https://www.rockvilleaudio.com/rt6/...uCwwLe8sDh0FlFO_rAfa9YPgG7JEDUJQaAuBPEALw_wcB
Marine tweeters for deck/dash
https://www.amazon.com/Polk-Audio-DB521-5-25-Inch-Speakers/dp/B000P0PF8C
Door speakers
https://www.rockvilleaudio.com/mac65s/
Speaker encloser
https://www.amazon.com/Infinity-Reference-612m-High-Performance-Loudspeaker/dp/B00292XT2I
Infinity speakers 4 ohm/amp rears
Infinity Kappa 62.11I 150W 6.5-Inch 2-Way Kappa Series Coaxial Speakers https://www.amazon.com/dp/B009GHQX5O/ref=cm_sw_r_cp_api_i_ey0DCbFAB1Z2S
Infinity speakers 2 ohm/amp rears
https://www.rockvilleaudio.com/rw8c...XsIKH8bMi6S-5FO_URLbuvZehIdrQEFQaArhhEALw_wcB
All in one sub woofer
