Wire harness help
Vitalik_Flash
Yes the harness is in the process when you combine both harnesses together, man harness, and the engine harness you need to add wires extend the wire sold them together, etc. sir thank you for replying
Markm
You are being volun-told. I hear by knight you Finisher if all that needs finishing!
I wouldn’t mind if I had a way to test it like I did my own. I had all the components on the table and test run the engine to make sure everything worked before I put it in the car but being his is newer than mine (different pedal sensors and a few other things) I wouldn’t be able to test it like I tested mine
comegetjoe
Excuses.
ccgillett
I bought a build in progress (and it's still in progress...), and it came with a wiring harness that was in the "50-60% done" range. I looked at it for a bit and decided to send it to DF. I actually paid a bit more than their quoted price, precisely because it was "60% done" and it wasn't right.
It came back as a thing of beauty, everything in it's correct place, approximately 97 rolls of tape used to hold everything together SOLID. It's big and heavy and was a bit difficult to get into the car - but I know whatever issues I have or will have with the car, it is for sure not the wiring harness.
Send it to DF, be happy and way less stressed!
