escapepilot
- escapepilot Goblin Guru
2006 SS/SC Donor had aftermarket headlights and some front end damage.
1. I have two purple wires from the same terminal. One was already cut long ago. Other is attached to a plug that was plugged into the left headlight housing. Neither had enough wire for DRL loop.
2. Left headlight plug had light blue wire with several loops - left DRL?
3. Right headlight plug had medium blue wire with several loops - right DRL?
4. Thick ground from multi plug is about 13”. Wrap small ground wires from lug to multi plug?
