V1 Clutch and brake bleed question
ToothMagician
Update: the car is back together just a few small things to button up. The elbow was leaking, I removed the extra seal and put the remaining one on the feed tube firmly. I reinstalled the elbow, but it got angled downward when I put the battery box in and wasn't sitting perpendicular to the feed tube causing it to leak again. I just grabbed the metal clutch line and bent it up so it sat correctly and now I think it's stopped leaking. Only time will tell. But i'ma make a video explaining everything and the issues that I had incase anyone runs into the same problem.
comegetjoe
Good to hear and keep up with the videos.
That’s what happened to mine. The line was pushing on the unmount area causing not to seat fully and leak. After some line bending, I ended up shaving the mount area where it was hitting to get everything flush and relaxed.
