Briann1177
- Briann1177 Goblin Guru
Also make sure you get a new head gasket.
Tilt one side up (i.e. exhaust side) and pour solvent into the port. If the valves are leaking, the solvent will run out. Do it for the intake side also.
No leakage, valves are good.
I replaced mine. After I found out what the total torque was on them I would not do it again. I don't believe that they are stretched all that much to the point of needing replacement.The service manual doesn't call for replacing the bolts when reinstalling the head. Just says clean with a nylon brush and blow out the bolt holes.
As far as going with studs, I wouldn't worry about it. I'd just stick with bolts.
My reading comprehension is a fail this early. It does call for new bolts. Main head bolts are 22 ft-lbs + 155 degrees and the four front bolts are 26 ft-lbs.
I just can't image the stretch on steel bolts when bolting them to cast aluminum. There better be a lot of thread in the block.
