Didn't do the tap yet as I wasn't sure if i should try and tackle the rest. I didn't pull the pan and really didn't want to mess with it. As im not sure if its an easy drop.It does look like a large enough hole to me. You could use a round file, or a burr on a rotary tool to round off some of the sharp edges.
Did you run a tap thru it? My drilling didn't get the hole completely round either. I also had the drill bit start slapping when drilling a partial hole.
Its not full I used grease and vacuum. The oil didn't have no shaving. I guess its safer to pull it and be positive. Is the subframe in the way to drop the pan?I think the oil pan is easy. Just bolts and RTV sealant. Besides, if it is full of aluminum chips, it isn't really a choice now.
You still have chips in the pan. No way that it didn't get some down there. Do you want to pull the pan and be sure or risk a metal chip getting lodged into a rod bearing?Its not full I used grease and vacuum. The oil didn't have no shaving. I guess its safer to pull it and be positive. Is the subframe in the way to drop the pan?
Yea I most of that already I would like to know if anyone has done baffles or if its worth it. Also noticed a spot which looks to be used on other models. Maybe for an oil sensor of some sort? Like oil level im just guessingNice chip collection. I would have guessed you got most of it using grease and a vacuum. I guessed wrong.
Skip the "while you're there". Thread the turbo drain hole, clean it, RTV it, and install it. Get that thing on the road, drive it, and learn what it needs next. My guess would be suspension adjustments, and sticky tires.
Alternatively, you could do forged connecting rods, forged pistons, while you're there, cams, valvetrain.... etc.
