V1 Fozda's Standard Track Goblin - 06' SS/SC #196
Fozda
Haven't updated in quite some time...the engine we slapped in ended up having a crazy amount of ring blow-by that was causing some big problems. I have acquired an engine in much better condition and will doing a mild build over the winter so that the car is ready to go again next spring!
Fozda
Hello again! Engine #3 is almost completely swapped in the car and ready to go! During teardown of engine #2 it was discovered that we failed to check the intake manifold for blown engine debris from engine #1 so after it was reassembled that debris quickly found its way back into the cylinders causing that engine to fail. Live and learn! Hopefully engine #3 lasts a little longer!
PXL_20230128_230104160.jpg PXL_20230108_222354179.jpg PXL_20230114_224914746.jpg PXL_20230129_220159266.jpg
Fozda
We finally finished building the trailer out of a Cobalt donor shell! I picked the shell up from another Goblin builder that's fairly close to me since mine went to the scrapper 3 years ago. We changed a few parts out to make it look almost identical to my donor though! The build took longer than anticipated but it turned out pretty awesome I think!
comegetjoe
Theyre a classically good looking wheel.
Are they 17x10? What back spacing? I ask because I think those are the wheels that Id like on my goblin when time comes to order.
Fozda
Had a bit of an incident at autocross yesterday. Picked a fight with the wall and the wall won! Unfortunately I wasn't recording so there's no footage of the incident. I haven't torn it apart yet to assess all of the damage but so far it appears that the frame is fine and I'll just need some suspension parts. I emailed DF about getting some replacements so hopefully I hear back in a decent amount of time.
Fozda
Car is back together and should be good to go! I'll get it out and test it today to make sure. I messed up the stainless brake line while putting it together but I didn't want to wait to get a new one to test so I found this rubber one at Oreilly that's meant for a Hyundai Veloster. It's not a perfect fit but it was close enough to get by until the new line shows up.
View attachment 42186View attachment 42187View attachment 42185
This was posted on the Classifieds section, maybe he'd split them up for the two of you?
