V1 Free spinning driveshaft?
PHENDERSON
P
I'm about to attempt my first start...more scared than excited. I had to install my driver side driveshaft to prevent trans fluid from leaking out. Is there enough friction in neutral that if the engine is running my driveshaft will start spinning? I don't have any of the rear end finished so it's hanging un supported.
Yes it will. Use some jack stands or anything to help support them or you could mess up the bearings inside or even the rubber boots
jirwin
Tbh, I'd start it as is with no CV. Trans fluid is super easy to change, so just change it before your first rip. It'll literally take you all of 5 minutes.
Special tool for the project
