Brad,
You list "PK3+ Bypass" as an unsupported feature. I take that to mean it's a "use at your own risk" feature, but it works? It's the main reason I am interested in this unit.
Thanks.
Requires the vehicle to be equipped with working Cruise Control to navigate the menu.
I'd be interested in the module and would be more than happy to test/debug; however, I think these two items are deal breakers are for me since I used a base model that didn't have cruise or power locks.Has the factory remote and knows how to pair the TPMS sensors with the vehicle
im curious about this too, as my donor doesn't have cruise either i believe.I'd be interested in the module and would be more than happy to test/debug; however, I think these two items are deal breakers are for me since I used a base model that didn't have cruise or power locks.
TPMS
The interface will work with or without TPMS. I just need a tester that has TPMS because I want to test as many functions as possible with one or two testers.
Cruise Control
Cruise control is required to navigate the menu(s). I will likely default the menus to the most common config so the module will work even without cruise. For example, the default config would turn off the warning lights and enable the door pin output (the primary goals of this project).
I can't imagine that actively driving would have to entail much more than around the neighborhood, but Bradr might want a more thorough test of driving in all conditions.
