Hole alignment
Leo Zugner
L
Did anyone have issues with the holes in the windshield bracket not lining up? I have the rest of the bolts test fit into the hood but the last one doesn’t line up. Hoping I don’t have to drill it out.
L
On a related note, I can’t figure out how the holes line up for the seat brackets. I have the wider seats. They line up with the frame sort of but then not even close with the seats. Is there a vid for this?
Jmar1622
Yes, I just adjusted it so the wrong holes were covered by the bracket
Markm
The wife’s was off just a little bit on the left side so I used a drill and reamed it out and it went right together without any issues.
SmsDetroit
Mine seemed off when i started on the outer edge on one side and worked my way across. I tried to start in the middle and then add bolts back and forth on either side and it lined up correctly
L
Gotcha. Thanks. I tried that too but it seems to be juuuust a touch off. I ended up making all of the holes in the body panels just slightly larger. It helps with assembly.
