V1 Jeffrey's City Goblin SS Turbo Illusion Purple
You should have got one of those from us with your turbo kit.
I will check on it with Adam tomorrow.
Jlarson524
Perfect! Thanks. Also can you ask him about the paper work so I can begin registration? I’ve sent a couple emails with no response. Not sure if they’re going through or not.
There isn't an adjustment that I'm aware of to make things smoother. As long as all your gears work, then that's about all you can adjust. However, if you over tighten and squeeze the two Y-shaped shifter yoke things together on the tunnel cap, then that can make things more difficult. I put some white lithium grease on the bolt and barely tightened it down. Also, make sure you don't have any tight bends anywhere.
http://dfkitcar.com/forum/index.php...8-ss-tc-registered-105.726/page-18#post-14967
Jlarson524
I found in the forum what size the brass elbows are and found where the one on the MAF goes but still haven’t found where the one on the MAP leads to. Any help would be greatly appreciated.
Dominator light: yellow is low beam, white is high beam, brown is running lights, black is ground.
Goblin: yellow was low beam, blue was high beam, brown is running lights, black is ground.
The yellow and blue with the stripe go to the passenger side, the other blue and yellow go to the drivers side. I used the fuses to figure out which side they were wired to. I split the brown wire to go to both headlights.
Jlarson524
I have purchased the dominator 2.0 headlights and they have a different wiring. Just curious if someone running them could tell me what goes to what
Those are different! Sorry, I thought I had Dominator 2 headlights, but I must have Dominator 1.
They only have 2 wires per bulb... and a common blue wire. Probably blue is ground.
BaltimoreHokie
I bought a pair of connectors off amazon and spliced them in. There are only a couple wires...high. Low and ground. Just connect power and go from there.
Jlarson524
What goes into this vacuum hole? and what plugs into the plug in the first picture?
Pic#1 downstream o2 sensor You wont have one unless you are running a cat
Pic#2 From what I can see looks to be where the TMAP sensor on supercharged intake manifold
Jlarson524
Can anyone tell me what this bottom right wire goes to on the instrument cluster? It looks like its breaking. At the moment the speedometer isn't working and I am wondering if that wire could be the culprit.
mnKevin
It’s possible, it’s a gray wire that connects multiple functions like hazards and fog lights. Connects to white bcm plug
