V1 Kenny and Ashleys extended city goblin- 08 SS TC DONOR #218
Fozda
The spring will be above the tire once properly adjusted like Zoom Zoom said so it should end up clearing unless you're not even close. What size/offset are you running?
Zoom Zoom
Oh man thank you. So you are saying measure 3.5 inches inside that tube that has the hole to mount it? I will do that as soon as I get home. Thank you.
Yes exactly, you turn the threaded shock part one way or another to get 3 1/2 “ on inside of mount
Kenny123
Got the brakes bled and the clutch bled. Found both front brake lines leaking very slightly on the front brakes where they meet the flex lines. I hope I don't need to replace those line already :-(
Were they new lines to start with? Many new lines and fitting leak until you get a really good seat on them. Ours leaked after I had tightened them as much as I felt comfortable with without stripping them. But ended up loosening them and re-tightening them a couple of time to make a good "seat" and that took care of it.
Kenny123
I will try they then. Maybe just loosen em up and keep tightening with a different seat position
Kenny123
You need EPDM tubing, by the way. Do not use fuel line or other rubber, brake fluid will degrade it. I got 10 feet of it from Tractor Supply for 8 bucks.
Oh no I am not talking about that tubing. I used the vacuum line provided and that worked fine. I'm talking about the compression fitting where the hard line connects to the stainless braided line. I think I got it by tightening the ever loving shi* out of it.
Kenny123
Going to run the shifter cables and mount the shifter tonight... I know I've seen a post i believe by lonny on how to adjust the cables and such. Can't seem to find it now. Also any idea where the power comes from for the intercooler pump?
