That tube is included with every kit for turbo donors.
"MAF" pipe?We got our kit after an estate auction of a friend that passed away after the car did not sell for the reserve that the kids had placed upon it. the kit had also been in storage from 2018 thru 2023 so many of the parts could not be accounted for at the auction. that is one big reason it has been a major uphill battle to source these parts.
i am wondering if i had 2 of these a bit of work with the Bridgeport mill i could modify one so that it became the MAP pipe?
drives side engine/ power train mount. this is a turbo car.
Turbo inlet (T04) is 2.36 inches (60 mm) - needs a reducer joint from 3.0 inches from the MAF pipe. Turbo outlet (T04) is 2.0 inches (50 mm) - needs an expansion joint to match the inlet to intercooler (2.5 inches?). The intercooler outlet 2.5 inches?) - needs an expansion joint for the 2.75 inches MAP pipe - and this is the size of the LNF throttle body inlet. Was this what you needed?
The 'U' (135? 180?) should be 2.75 inches (70 mm) on both ends to mate with the DF MAP pipe - or sized to match the MAP you will be using.is the U or 135 degree pipe coming down from the cooled side of the intercooler to the intake also need to have a size change between the 2 ends? a
