V1 Lokian's Extended Street Gob in Indiana - 10 LS # 251
MR.812
Here's the crazy thing I don't have a donor yet. I just want to get on the waiting list.
L
It has arrived :)... and ****... it is smalllllll o_O .. I'm glad I went extended street after seeing the full frame. Now to find all the parts and find storage for it all.
20871
L
Running list of items to do and figure out.
  • Clutch
    • clutch
    • throw out
    • resurface or replace flywheel
    • fix shifter... need new plastic bushings
    • need clutch pipe
    • master cylinder
  • Engine maintenance prior to install
    • rear main seal
    • timing set
    • water pump
    • spark plugs
    • O2 sensor
    • serp belt
    • Fuel Filter
    • Fuel cap
    • exhaust man studs
  • Drive train
    • Hubs
    • Tie rods
    • axles
    • Rack and pinion
    • output shaft seals
  • Seats (NRG PVC)- would like ones that I can slide back and forth - ordered
  • Lights
    • Rear
    • front - figure out mounting
  • parking brake
    • parking brake tubes
    • ss parking brake cables
    • front brake pads.
  • Rims and tires - ordered
    • tires - r888 or N05
  • Dash
    • Dash night ligths
    • Dash rear view mirror
    • Dash buttons
    • Figure out mounting for the above
  • Paint
    • Axles
    • hubs
L
Some progress has been made and mistakes as well.
1. Got the frame and everything big to powder coater.
2. Got the valve cover back from stripping the messed up powder coating. Had to have a coater chemical strip it. Drilled out the baffle cover and then was going to tap some new holes in the valve cover to reinstall the baffles. YUP drilled a through the cover. Ordered new used valve cover
3. Painted new valve cover (black), brake booster, and pedal box. Decided to not powder coat valve cover purple and brake calipers purple as the whole idea was that if I wanted to change colors, I could do so easily. Chemical stripping the valve cover and brakes each time seemed like a bad idea.
4. Decided to order a reman rack instead of replacing seals on my old one as it was leaking during storage.
5. Somehow lost a master cylinder
6. Waiting on powder coating to get done so I can start :)
21245
21246
Lol. The master? Yes. The bolts? No. The older ones look worse than that.
