V1 Nukers City Goblin - 2009 SS/TC number 2 build
TheNuker
Does anyone have the part number for the 3 alternator bolts for the LNF? Or the size and length? I've seen M8 x 130mm but can anyone confirm?
Thanks!
Nuker-
TheNuker
Got the intake manifold throttle body and alternator installed, waiting for more parts now!
TheNuker
Ooo! New parts! Is that an exhaust pipe with the welded bung? High pressure fuel pump and a stage 3(?) clutch. :D
You got it! South Bend stage 3, I was going to do a stage 4 but.... With the weight of the Goblin I think this will be just fine. I'm going to use that welded bung pipe for a dump pipe off of the turbo for the tuning and a wideband
Nuker-
TheNuker
Let us know how that clutch feels. I’m having trouble building an engine ZZP is out of a ton of stuff.
Will do, Everything I read says it feels like stock but holds a ton of power. My first goblin using the SS/SC and GMPP held the 275 no problem. But with this engine making 350+ and a ton of torque I decided I better do something else!
Nuker-
TheNuker
High pressure fuel pump installed, but ran into a little problem with the manifold pressure sensor the bolt hole does not line up.
anyone had this issue?
Nuker-
Remove about 90 degrees of the steel tube in the bolt hole... it will work as there isn't much upward pressure on the MAP sensor. I guess the sensor was made for a different engine casting.
