Good to know. Thanks Chad.The connector basically tells you which way they are facing. Keep the connector as perpendicular with the engine as possible. You can see the split pattern on the end of the injector. Install them just like you would a normal injector, but just keep they perpendicular as there is nothing to lock them into that position. Once they are installed, the o-ring pretty much holds them in place.
I thought the same thing and was trying to wrap my head around it all. Which way is the correct way and everyone was arguing about it, I never knew for sure. When I talked to my tuner, he acted like you don't need to do any of that junk, just tune the VE table. Since I'm using the boost referenced fuel pressure system, my fuel delivery over the entire MAP range is pretty much the same value since the fuel pressure compensates for the changes in MAP. So I just entered 62.5 lb/hr over the whole range of Flow Rate vs KPA. I left all of the modifiers alone other than the Min PW and Short Pulse. But I'm using 60 lb/hr injectors so technically is correct. But what was really throwing me is the rating of the injectors, is that 60 lb/hr at 3 bar or 4 bar fuel pressure???? I assumed they are rated at 3 bar but our fuel pressure is at 4 bar, so is a 60 lb/hr actually delivering say 72 lb/hr? If that's the case, will your 80 lb/hr be delivering 95 lb/hr at 4 bar? I tried emailing the guy at Injector Connections where I got them but I could quickly tell he was a dumb ass and knew nothing about it and didn't want to be bothered with tuning questions.
The stock Flow Rate Mult vs Volts is set to 1.0 in all cells. So it's not really being used in stock form. Typically it's only going to run on the last two cells, 12 and 13V. You could adjust those below it some if you really wanted.I notice that a lot of tunes just blank out (or set to 1x) the whole table. Defeats the whole purpose of the table!
If my whole "Flow rate multiplier vs Volts" table is set to 1.56x, then the engine can't compensate for different voltages.
If your whole flow rate vs KPA table is 62.5 lb/hr, and you tuned the engine on a low pressure day, the engine can't compensate for a high pressure day.
Anyhow, I was hoping to tune my "Flow rate vs KPA" table, by starting with a properly tuned stock engine, then changing only the injectors, and modifying the "Flow rate vs KPA" table with any wideband O2 errors that I logged.
This might not be the minimum list, and it is for my 2006, but here is the PIDs that I log:Could we get a list going of what is the minimum things we need to datalog and maybe even place them in the same order. That way when we share files it will be easier to follow for the new guys to using HP T. (Yeah Me Right Now.)
Ross,This might not be the minimum list, and it is for my 2006, but here is the PIDs that I log:
Just downstream of the existing O2. Sorry I don’t have a photo yet. Look under the DF exhaust and you see it on the driver side of the inlet pipe.This is a simple question, but can I get a picture of where the wideband O2 sensor is installed versus the existing O2 sensor?
The base models did not have a bung in the exhaust manifold. See attached.Weird... there’s no spot for a sensor in the manifold. I’ve got a spot in the DF exhaust where I have the narrowband stock sensor in place. Looked at the donor pictures as I was taking it apart, and the exhaust itself had two sensors, one before and one after the cat converter. I guess the LS model is different than the the other models?
