SC Heat exchange plumbing
Towerdog
Towerdog
Anybody have pics or want to share how the heat exchange is plumbed in up front?
There are 4 90 deg NPT to barb fittings and the Pex lines have Pex couplers that are smaller that the barb fittings. It seems like if you put the 90s in the radiator pointed at the tunnel then add hose from there to the Pex it would kink...
Towerdog
So I am pretty much at a stand still as I do not know how the rear PEX mates with the engine. There are no supplied couplers of that size......
Brett
I took the U and cut it in half to make the L hose.
Also, you use more heater hose to go from the pex to the pump and intercooler, at least on a TC. Not sure which model you have.
Towerdog
Thanks I have a SC. I cut the "U" for the front to the heat exchange.
V
Does anyone have pictures or details for SS/SC Heat Exchanger Install? Is there only two screws to hold the Heat Exchanger to the frame? Is there not a fan on the Heat Exchanger?
Towerdog
Yes only two screws hold it to the frame. If you did not purchase the duct kit there is a fan that ataches to the radiator.
V
Sounds like you should’ve received the fan then. Message dfgoblin support and they’ll send one out to you
I need to clarify I may have the fan I have not checked yet. Mainly I need to understand the rear of the heat exchange install? I see the diagrams but what hoses and parts do I use?
jayrolls
I was able to mount the fan and the ducts. Just had to make some pieces to space the duct plenum up a little to clear the fan.
