Sluggonaut
- Sluggonaut Goblin Guru
Slowly working through the winter project list.
I've got the intake cleaned and the timing chains replaced. Just waiting on a gasket and some copper washers to call that officially done.
I finished the brake proportioning valve install tonight. That took a little longer than expected as I ended up removing the radiator to get to the front brake tee. It was a good time to work on it because the brake lines and cooling system are both open/empty due to dropping the subframe to work on the timing chain.
