SmsDetroit
Lots of clean up to do but the engine cover has its rough fit.
SmsDetroit
Been working with a friend who is a body guy working on the hood. Starting to look good
SmsDetroit
Got the wing uprights back from powder coat. No just need the body panels back. Also I think I found my coolant leak at the heat exchanger. I may have over tightened the hose clamps
neodied
Not a bad days worth of work. Completely replaced the engine harness with a brand new one from GM. Also replaced the valve cover gasket while I was at it. Looked pretty clean inside. Not sure if you can see it but there is at least 15 wires in there missing insulation. Also found the MAF wire had been spliced 6 times plus several other sensor connectors replaced. Though it would be best just to replace it all with new.
Do you have a GM Part # for the new harness? May be useful for other people with rough donors as well.
SmsDetroit
So the requirements for glass, winshield wiper, windshield washer and bumpers are optional? Or do you have to slip the guy a hundo...
The guy that did the final inspection didn’t even look. I kept him occupied with showing the horn, all the lights and seat belts. Then I started talking about the build and he slapped the vin on it
jirwin
I have this same question in the Michigan Builders thead, but I'm curious @SmsDetroit . Did you have the boxes checked for safety glass and all that on the TR-54 when you turned it in, or did you leave them off?
SmsDetroit
Man what a difference the wrap made. Love the look.
