V1 Tim's #547, 09 SS/TC LNF
tim1972
T
Retired Mechanical Engineer.....now full time car hobbyist.
Car will be used to enjoy riding the twisty highways of the Texas Hill Country.
Purchased the non running donor some time ago and started the project late 2025. Engine started but surged really bad.
Replaced MAF sensor, coils, and plugs and started and seemed to run good. Couldn't drive because rear wheels were froze. All cylinders were a consistent 140psi compression.
Disassembled engine and measured cylinders and bearings. All were withing tolerance except cams so I bought new GM replacements. Disassembled and cleaned the heads and components. All valves passed the vacuum test after reassembly.
Turbo casing was cracked so sent it to the scrap pile and bought a new GM replacement.
Engine rebuild less turbo was finished 1/8/26.
T
Stages 1 and 2 progress:
After major delays was able to complete most of the second stage build around mid June, 2026. No major problems putting the kit together. Adam and crew put together easy to follow wiring harness rebuilding and mechanical assembly videos which made the process quite painless.
Made a mold to make a fiberglass roof, finished the roof, and finished painting all the fiberglass body parts with a pearl base coat and lots of clear.
Got a major obstacle with the engine that may be asking for input from others. Tried starting for the first time at the end of May. Difficulty starting engine and when it started it surged. Codes were P2146, 2155, and 452.
Replaced all the injectors, coils, cam and crank sensors, checked all the wires for continuity, checked all the grounds, checked the injector high and low supply voltage sides coming off the PCM. All those passed except the low voltage supply side coming off the PCM. This led me to believe a failure at the PCM I/O Low Side Drive Switches in the PCM. So I bought a new PCM from Flagship. After installing the new PCM I still have the exact same issue.
Returned the PCM back to Flagship for evaluation and currently waiting for their findings.
Not sure what that last code # actually is but if that is the same fuel injector supply voltage circuit open but a different cylinder then I would expect a ground issue. It's almost always a missed ground on wiring issues with these cars.
But this is without looking at the service manual to dig into what is shared or the particular meaning of these codes that the service manual will provide on what actually sets them.
You need to add your donor information into your signature so it will be obvious what you are working on as you get away from the first page. I assume you are working on an LNF not a NA or SC with a turbo added.
T
Thanks for responding.....Yes, it's LNF, TC. I'll try to figure out how to put it in the signature spot.
So my understanding is that all grounding for the engine sensors, ignition, and fuel management goes through the ECM and connects to ground through pins 1, 2, and 4 on the X2 connector. I have checked these three grounds on the X2 connector and they are all solid grounds.
Not worried about the 452 code....pretty sure it's the 2146 and 2155, basically failing injectors, that's causing my grief.
Certainly grateful for your further comments.
Thanks
