V1 Tires and Wheels List Updated on 3/25/2020
Metal Mech
Chassis Number 398
Frame Type: Standard Track
Color: Prismatic Powders Custom creation 756, Mystic Purple Base, Chameleon Teal Topcoat
Donor Year / Engine: 2010 / 2.2 XFE Base Coupe
Engine / Trans: 2.2 LAP, ZZP LE5 Cams, Neutral Balance shafts, HHR Big runner intake, 3582r chinaboi, Saturn Vue 4.41 gearset F23 transmission
Wheel Make / Model: Konig Hypergram
Front Wheel - Size / Offset / Bolt Pattern: 17x9 / +45 / 4x100 (57.1x73.1mm Aluminum hub centric rings used)
Rear Wheel - Size / Offset / Bolt Pattern: 17x9 / +45 / 4x100 (57.1x73.1mm Aluminum hub centric rings used)
Spacer Dimension: 4x100 2" thick 57.1mm Hub/Lug Centric
Wheel Weight in lbs.: 38.3lbs
Tire Make / Model: Nitto NT 555 RII
Front Tire Size: 275/40R17
Rear Tire Size: 275/40R17
Seat Make / Model: Corbeau
Hey it’s the chassis right after mine. Your done already and I’m just starting haha.
Cnixon160
I have a few hundred miles on mine and daily drive it while religiously beating on it, its a blast to drive and gets ~30MPG.
Metal Mech
Im #383 and been driving it almost a year now LMAO, get it done! I know you had issues with the powder coat though.
Yeah still waiting on that to get back. I also needed a shed so I had room to work on the garage. Then winter came and the donor sits outside and I can’t work on the cold.
Making progress now though. Biggest hurtle at the moment is budget.
Metal Mech
Also since I totally got this thread off topic.
Kansai KNP 17x9.5 +12 in a 5x114.3 pattern
Haven’t gotten tires yet but going 255/40R17. Probably BFG.
Will be powder coated to match frame.
SmsDetroit
I built mine in a car port in the middle of winter in Michigan. Get it done. Lol
Metal Mech
Yeah no not happening. No car port. Open air drive way. I also didn’t have room in the garage for the parts I am stripping. I spent the winter cleaning up and organizing the garage. I plan to have the car completely stripped before winter so I can keep working in a comfortably warm garage.
BSinvestments
Please make sticky at the top of this thread:
Updated list (3/25/2020) of chassis number, frame/color, donor year/engine, installed wheels, wheel weight, tires and seats on everyone's Goblins. I need help filling in the blanks. Please send me the following info and I'll add it to the list (or send corrections if needed):
Goblin Builder:
Chassis Number:
Frame Type / Color:
Wheel Make / Model:
Tire Make / Model:
Front Tire Size:
Rear Tire Size:
Seat Make / Model:
Click on list to make full screen and easier to read.
Thanks,
Jeff
If you would like to update Chasis #74
Goblin Builder: Credit to BaltimoreHokie, all though a lot has changed
Chassis Number: 74
Frame Type / Color: street
Donor Year / Engine: 07 LSJ-T
Wheel Make / Model: Vision 571 Sport Star II / MST MT11
Front Wheel - Size / Offset / Bolt Pattern: 15x10 5.5" / 16x8 +15
Rear Wheel - Size / Offset / Bolt Pattern: 15x10 5.5" / 16x8 +15
Wheel Weight in lbs.: 21lbs / 15lbs
Tire Make / Model: Nankang AR1 / Toyo R888R
Front Tire Size: 275/35-15 / 245/45-16
Rear Tire Size: 275/35-15 / 245/45-16
Seat Make / Model: Corbeau FX1
My street tire setup up is MST MT11 16x8 +15 backspace with 245/45r16 Toyo R888R
My new track setup is Vision 571 Sport Star II 15x10 5.5" backspace (571-5165B0) with Nankang AR1 275/35r15
42221
