ATMironov
- ATMironov Well-Known Member
Hey Everyone,
So I'm in the research phase of the goblin build with a plan to order a kit and build it next winter.
The car will be a dedicated track car and I would like to use as many new parts as possible.
I run an Track Day/Race event company in Northern California and am at the track 2-4 times a month.
I haven't been able to convince myself one way or the other yet if I should buy a donor or not.
The plan will be to buy a new LNF or LDK long block from ZZP or someone else, and a new/rebuilt F35 w/ LSD (Maybe from Performance Autowerks).
Also, any consumable items (bearings, tie rods, master cylinder etc) I will buy new.
So with all that in mind, I know there are still parts I'll need used, the most complicated of which I think will be the wiring harness. I'm not sure of the reality of pulling a complete harness from the junkyard or finding someone selling one.
I have a healthy budget for the build ($35k ish), but don't want to needlessly spend money and time on a donor.
I think this is all the items I will need used:
All Wiring
Body Control Module
Horn
Subframe
Front Knuckles
Coolant Take
Brake Fluid Reservoir
Brake Booster
Shifter
Steering Column
Ignition Switch
Pedal Box
Turn Signal Switch
Fuel Filler Neck
Brake Line Clips
So I guess I'm looking for input on if it's a bad idea to not buy a donor, and what suggestions anyone would have for finding a wiring harness?
Also, if I could just find an engine wiring harness from a LNF, could the rest of the harness be from any Cobalt or should all the wiring come from the same car?
Thanks!
All Wiring
Body Control Module
Horn
Subframe
Front Knuckles
Coolant Take
Brake Booster
Shifter
Steering Column
Ignition Switch
Pedal Box
Turn Signal Switch
Fuel Filler Neck
Brake Line Clips
Thanks!
