Christopher Sanchez
- Christopher Sanchez Well-Known Member
Hey guys, so I am having pretty significant wheel wobble under heavy braking to the front two wheels.. Now my goblin is no where near “dialed in” since my first drive i have made corrections to the alignment but no local will work on it.. I have one friend of a friend. A tech at a local Chevrolet dealer as agreed to give it a shot on his day off but Our schedules have not lined up.. I ended up purchasing some toe plates and used the level on my IPhone to adjust the rear. The car is MUCH more controlled under acceleration after this adjustment.. I am still on the stock bushing in the rear and you can see a definite flex in them so solid bushings are on the list.. so back to the front I remember riding in the SC kit at DF and Lonny would hit the brakes and instantly the car would lock up and stay straight.. now I have adjusted the front toe using the toe plates and was surprised when this issue did not seem to improve.. I have yet to set the front camber so I hope this will eliminate this issue.. I have also set the front shocks close to the stiffest setting which seemed to help the fronts remain stable when riding at highway speeds on bumpy roads.. I have used the thread on adjusting the alignment and plan to finish the front but I am wondering if any others have had this issue. I should also mention the rear is on stock springs that I cut a tad low so the rear is probably .5-1 inch lower than the fronts until I buy the coil over kit. Any advice is appreciated!
