AleX1/9
- AleX1/9 Well-Known Member
Where did you get the headlights?
If you google "dominator 2.0 headlights" they'll pop right up. I ended up getting a RHD set for a good deal which was perfect, as I swapped the RHD blockoff plate for a LHD "bixenon solenoid" which gives a Hi/Low function to the single headlight. The Arial Atom uses 2 pairs, one hi one low each side, which is probably a better way to go if you need to pass an inspection to register the Goblin. Even then, I'm not sure the DOT markings are correct, so I might have to get a temporary set of cheap DOT lights to get it registered.
