KingChuck24
- KingChuck24 Well-Known Member
Which switch, the one that connects to the D1 pin and the accessory power?
I'm dealing with a wiring issue of my own and digging around in the forum I came across this post that has excellent layouts and wiring descriptions for every wire and connector in the car. Might possibly be useful to you too. I think it starts at post #158 if the link doesn't automatically start there, and continues for about 12 posts after that.So I just checked it again to be sure and I when the key is turned I got no voltage when pin 2 was being touched and ground was being touched.
No. This means that the switch is not supplying power to C8. The diagram indicates voltage flowing from B+ (basically Battery Positive) through the ignition switch in the run position (and probably accessory position) and out pin 4. This voltage then flows to both BCM pin C4-c8 and TDM pin 2. The junction point/split is in different location for the manual transmission(M86) and the auto trans (MN5).So from pin 1 on the alarm module connector which is the red and white wire I am getting battery voltage. On pin 2 I am getting no volts and that should go down to c8 on BCM plug c4 and that is also not getting voltage. Does this mean that the anti-theft module is bad?
Actually I'll change that.Why don't you want to check the ignition switch? It supplies power to both the BCM and the TDM.
