- gofast Active Member
Prior to installing my clutch slave cylinder/throw out bearing assembly, I thought I would pour brake fluid into the cylinder to aid in the bleeding process later. I poured fluid into the block where the fluid line attaches and then squeezed the piston thinking air would expel then released expecting fluid would get sucked in. Nothing happened. Even pumping the piston, the fluid just sat there. Thinking something must be wrong, I did the same thing with a second, well used cylinder with the same results. This cylinder is nearly new and with the second one doing the same thing, logic says this should be normal, but the mechanical part of my brain says something is wrong. Can someone enlighten me?
Also, my donor was a SS/TC. I have seven transmission bell housing bolts as I should, but three are stud bolts. Everything I've read says there should be only one stud bolt. I didn't make note of the bolts when removed (shame on me) so I'm not sure where to install the other two stud bolts. Can anyone tell me if three stud bolts is correct for the SS/TC, and if so, where they go? Thanks!
