I believe they has some space up in Mountain View.you can see a little more of it in the new VW project blog
It being a tube maybe the rack goes in the housing only from one side? Feel free to destroy one and find out. I'm curious too but mine are working this way so not inclined to dig further.I was sure it was as designed, just not be able to see inside to understand the internals it seemed odd.
Just now disassembled steering wheel. I always seem to have a hard time popping Air Bag out
I noticed that on mine as well. Something I too will have to do.Although the mounting holes for steering rack were spot on, as I had to do with Goblin 1.0 I had to enlarge the clearance hole that Steering Shaft goes through. I would say between 7 & 11 O’clock? would have been cleaner if had done that before mounting the panel.
And the lower shaft can only go on one way because the bolt needs to go thru the clearance radius on the shaft.
How nice is this going to make working on the Goblin going forward.
Little extra height than jack stands.
