KingChuck24
- KingChuck24 Well-Known Member
Hello everyone,
I recently pulled the engine out of my car and trimmed down the engine harness as well as rewrapped some parts. While doing so I must have either knocked something loose out of its socket or cut an incorrect wire.
Currently the car is running and driving but the engine does not feel right and on top of that the coolant temperature reading on the dash when in neutral sits at 106 and when I drive the car it jumps around from as low as 30 all the way to 300. When I plug in my scanner I cannot get it to read the ECU at all and it wont connect to the car.
I tried looking for some things on my own and testing the grounds by the engine which all checked out. I checked the pins on the C101 connector which from what I gathered carries the GMLAN connection from the ECU up to the BCM and those checked out.
Has anyone else ever had this issue?
I'm going to keep trying over the next couple of days to get this fixed but my planned track day this coming Wednesday might need to be canceled.
