Bigfoot Goblin
Always better to have the coolant pulled from the bottom of the radiator where there will be fluid, rather than from the top where it could betrying to circulate steam.Supply line to the pump should be connected to the bottom port of the radiator. Gravity will always work with in supplying water to your pump in this configuration.
Connected in this manner your radiator could only be half full and still circulate coolant. It won't the other way around as the pump can't pump air.
