Maybe use the original bolts for the bearing clearance check? Torque to spec ft.lb. value, then torque 1/2 of the additional degrees of turn - since the yield has stretched the bolts already getting to the ft.lb. value will take up most of the existing stretch. Just trying to think of how to do this without buying 2 sets of brand new bolts - since I will eventually be doing the same thing.Gotta learn the hard way I guess. I'm going to see if they'll replace the two I'm having trouble with, or if they'll just take them all back. ZZP doesn't sell the ARP main studs, and I can't find the stock ones on Rock Auto. OTTP does sell the ARP's but how they handle this situation will determine what I do regarding that. I really just wanted reusable ones so I can measure bearing clearances without having to use a new set of TTY bolts the second time.
Looks like the main bolts are GM# 11571239 and the Girdle bolts are GM# 11588733. Both seem a little spendy, but I didn't check ARP prices.They are grade 8 M8-1.25x80mm flange bolts if anyone's curious.
Both are available at RockAuto and other places. One odd thing - RockAuto says the girdle bolt length is 80mm, but another website says its 90mm. Weird.
... 8K RPM.
A couple of OEM parts websites call out the part number, but neither calls out the length:@snirtman I don't think the 10 girdle bolts GM# 11588733 is right. The RockAuto description says 0.9" of thread. Here is a picture with one of the actual bolts (right) and with one that I tried to replace it with that's grade 10 (left). The grade 10 doesn't have enough thread. The one you listed also looks like it would be around the same size. Where did you find the part number?
