V1 Mahkoi's #299. Ext Track. SS Turbo.
Mahkoi
I was able to find a Deka at a local shop for $165. Better than what autozone wanted for the duralast at $220. I didn't think about Walmart carrying batteries and there's not a rural king that's closer than 45min away.
Markm
Tractor Supply, Fleet/Farm, Costco, Sam's Club all carry batteries too. :D
Tractor supply batteries are expensive but in a pinch they carry a bunch. I’m almost convinced that all batteries come from the same manufacturer in china and just install different stickers for brand names cause it seems they’re all expensive and lack good life expectancy. Unless I’m the only one who has batteries going bad all the time.
A battery has a life expectancy of 3 years (or less) out here in the desert. The summer temperatures cook the life out of them. Doesn't matter if it's a cheap one or an expensive one, they all die a premature death compared to most other places. :oops:
I work in Supplier Quality for Mazda and we source our batteries from two production sites in the USA. Now, where their subcomponents come from is a different story. They at least make the cells in their sister facility in South Carolina.
SmsDetroit
My 2018 Hellcat is still rocking the factory battery out here in Michigan
Mahkoi
I decided to try and polish my windscreen since it was getting pretty scratched up and had a haze when looking through it. Came out better than I expected. Link below if anyone wants to know what i used
Before:
After:
NOVUS-PK1-8OZ-PM, Plastic Clean &... https://www.amazon.com/dp/B0029B518O?ref=ppx_pop_mob_ap_share
Before:
After:
This is interesting. I was planning on picking up a piece of shaded polycarbonate to cut a new windshield, but maybe I'll give this a try, instead.
Mahkoi
Thanks @TravMac for the camera suggestion and mentioning the Costco deal. I picked up an Insta 360 x4 and the motorcycle mount. I really didn't want the selfie stick sticking out over the car so this is my mounting point for now. I'll play around with it and see if I need to move it around.
Mahkoi
Decided to switch out the taillights to a different style. I like the Rigid ones but didnt want to spend the money so I got the Kemimoto chase lights. Made the brackets out of some aluminum plate I had and powdercoated them. Got them both installed tonight. I think they look better than the round ones that come in the kit. Only got one side wired tonight. I'll finish the other side tomorrow.
Mahkoi
I was looking at those. Are the blinkers red or amber? I want to say I remember seeing someone installing these with amber blinkers? What would you charge me to make some of those brackets?
The ones I have are red blinkers. As for making you a set, I'm really not interested in sending you a set, if you have fitment issues then its a hassle to make it right for you since you paid for them and i wouldnt be able to just say oh well and leave you hanging. The pics I have with my sharpie marks will get you off to a good start if you wanted to make a set. I traced the taillights brackets that come on the frame. Then traced the bracket that comes with the lights in the center of the C shape that I traced and used my horizontal lines to make sure light bracket was traced was "straight" so that the angle of both lights would be the same. I used a couple of pieces of 1/8in aluminum I had leftover from other projects. I have 1/16th too but it felt to flimsy for this. I cut the large sections out with a hacksaw, shaped it with a flap disk, then drilled the holes in it. Would have gone much quicker if I had a bandsaw.
I'm not trying to be a jerk and tell you I won't make a set, but distance makes it difficult for a weird little one off project that I half eyeball measured and kinda just made up as I went along.
Mirage775
No problem, I just hate cutting metal with my poor jigsaw :( Yea, I was think 3/16" thick? I have 2mm carbon fiber mounts now and they're somewhat flimsy, but I wouldn't think they would be as flimsy as 1/8" metal... I looked and couldn't find the ones with amber signals... I found some different interesting lights though :) I'm on my 3rd set of aftermarket lights, LOL!
Mahkoi
Ha i get it. I would think 3/16 would be fine. 1/8th is overkill for these but it's what I had on hand. I'm not sure how similar if at all the mounting is for the Rigid lights but some one on the forum had some pretty mounts they were making/selling for them. I think that's what @comegetjoe used for his rigid lights.
Mirage775
Oops, not 1/8", I meant to type 1/16", that would be too flimsy I would think? 1/8" should be pretty firm?
