I made huge progress on the Bronco audio project, this weekend.
I am not going to call it finished yet, because I still have to fine-tune the subwoofer crossover point, bass boost, and gain levels, and because a couple other little things popped up as I did the install.
First, I decided to add a capacitor to the system because, well, I can. Car audio capacitors are designed to provide high levels of current on-demand, as your amplifiers call for it. This reduces dimming headlights at night, and other "brownout" type problems. I went with a half-farad cap because I'm not running a lot of power.
Secondly, I decided I didn't like my plan to tap into the rear speakers to get the subwoofer signal. The Ford factory radio does some undesirable equalization and frequency elimination and, while the Kicker Key 200.4 amp I am using does fix that issue, I didn't want to tap into the signal after the amp, and use it with the high-level inputs on the subwoofer amp.. So, I installed a LOC from NVX. A LOC allows you to throw the high-level signal directly from the factory radio/amplifier to the LOC, which can then apply lots of shaping to the signal (HPF/LPF, bass boost, etc), before sending the signal out to your amplifiers at line-level. I didn't use any of the processing features though, the two Kicker Key amps do a lot of that themselves. I only installed the LOC for two reasons:
- You can feed 4 channels in (front left/right, rear left/right) and get 6 channels out (front left/right, rear left/right, and two channels of subwoofer signal). The frequencies in the signal are summed across all channels, which fixes the factory radio equalization issues.
- The LOC is able to use DC offset to sense when to turn on, and then will provide a remote out 12V signal to turn on your other amps. Both my amps also have DC offset, so I didn't technically need this feature, but I used it anyway, in case I ever want to change the subwoofer amp or something.
All in all, after the upgrade, the system went from sounding anemic, to sounding like a concert hall. I still have to tweak the subwoofer but otherwise, it sounds great! Unfortunately though, I am not done yet, most likely. For the near future, probably:
- The Kicker CS 4" speakers in the rear pods can't handle the full-range signal at very high volume. I have a pair of 300hz bass blockers here I am going to install on them to filter out all the low frequencies to see how that addresses the issue, while tweaking the subwoofer. If I can't get it sounding how I want, I will invest in a pair of rear pods that can take 6.5" speakers, and will grab a pair of Kicker KS series to install in them.
- During the install, I was annoyed to find out that, if you fold down the rear seats, the part you sit on moves forward as well. This means that I can't fold the seats down without removing the sub box from under them, making my whole decision to go with that box, pointless. If I need to remove the box for hauling capacity, I'd rather install a bigger box/bigger subwoofer(s) in the trunk. I don't know if I'll change this or not; it depends on how well I can dial in the existing box and subwoofer to complement the rest of the system.
Here's some pics.
Pro tip: Velcro straps and zip ties work amazing for installing gear in cars where you don't want to drill holes. Here's the capacitor and the Kicker Key 200.4 amp (zip tied to the other side of the kick plate), plus some closed-cell foam padding I wedged in on the metal edges to protect the cap and the wiring.
Testing the Kicker Key 500.1 sub amp. The Velcro straps around it will stick to the carpet under the backseat, it's not going to go anywhere.
Finished off the rear install. The entire install is next to unnoticeable, I did a really good and thorough job with it.
Current upgrade list and status:
- Audio - in progress, but mostly done
Side steps
3rd-party addon for rear hatch
Door pockets
Taillights
