- Robinjo Goblin Guru
Day 30 8/19/2022
Hours Worked: 2.0
Total Hours: 86.5
(Assembly Hours: 24.5)
In this installment we got the engine in the back of the frame. We rolled the engine into place and just lifted the rear over the engine once close. We did have a little issue with getting the bolts to line up, but that was mostly due to having the engine sitting right on a furniture dolly. If it had been on one or two 2x4's higher, then it would have been much, much easier. In the end, we got it. I was hoping to have all the coolant lines ran and fuse box installed, but the power went out for an hour due to extremely heavy rain, which I left my windows down for on my car.....
Also got a replacement front suspension bolt from Rural King. It's about 1/4" longer than the DF one, but probably only I will notice....
Issues to deal with:
Headlight (order new set)
Suspension Bolt
Engine Installed - Note: keep all the bolts loose until you get at least two in each side. It'll let you move the engine as needed. Also, have the engine on a couple of 2x4's on a dolly and not just a furniture dolly's base. It'll help a lot!
Hours Worked: 2.0
Total Hours: 86.5
