I'm famous now!Rauq, I just added your great thread on Wiring Wideband O2 Sensors to my build thread & indexed it.
Nicely documented.
Working on the issue as much as I can through out the day as work allows, but I believe your diagnosis of "pig rich" may in have been accurate. I'm gradually pulling the fuel pressure down lower and it seems to be running better. Stay tuned. Want to give it a few hours to cool off and will get back out there and crank it again.I'm famous now!
Anyway back to OP's issue, if AFRs are whack, we can dive into that, if not, time to start looking for vacuum leaks. The only other thing I can foresee from this point is a bad injector or spark plug causing a misfire, but I don't think it'd be idling that well if that were the case.
That should increase fuel pressure which pushes the system back towards pig rich, unfortunately.Or unplug the vacuum line.
I guess you could do that to set base pressure, but while you're doing that, the injectors are going to be getting ~20% more pressure than they should, and @finazzoty indicated pulling the vacuum line to the regulator kills the engine currently. Pretty sure when the engine dies the fuel pump relay turns off.I was talking about setting/checking base pressure.
If @finazzoty is just now getting to installing a wideband, Al with ZZP may not have seen anything more than a narrowband O2 reading of 1v or whatever narrowband rich is. Still would have been helpful IMO to indicate that as the issue rather than "the fuel is not making it from the fuel rail to the intake port in the correct amounts."Why are you leaning so much toward rich? It should have shown up on the narrow band either rich or lean when ZZP reviewed it?
Here is the most recent scan I sent them. I will pull another one later today after I (hopefully) get the wideband installed that will should be more informative.I would guess he is seeing a narrowband lean of less than 200mv and probably a very wide injector pulse to indicate that the ECM has tried to push it richer but can't go any wider. Of course this is a guess without seeing the data log.
For the sake of a productive comment, how sure are you that your tank of E85 is E85 and not like E50 or worse? That'd throw your fueling way off... in the rich direction.
