- Gtstorey Goblin Guru
As a wrap up on this, I installed the new fuse box this evening and I think the no start problem is resolved. It was more than likely a loose connection on the back of it. I had also picked up an occasional no crank problem and this weekend I pulled each wire from the X connector blocks and tightened them up. I could see through both the ignition coil connector and one of the crank connectors. I’ve had my fuse box apart likely more than most dealing with issues but I highly recommend that it you start having issues here to take the time to remove each one and “spring” the tab closed. Mine was a little easier since I had removed most of the original unused pins/wires when I originally stripped the harness.
I also got a call from the Alabama Department of Revenue inspector this evening and have an appointment to get my “assigned vin number “ inspection tomorrow morning. I’ll post what it took after I get final registration which I should be able to do this week.
