V1 Dragon Motorsports 2.0 [Extended\Open-Frame\Easy Entry Door Bars] - [2007 LSJ SS Donor] - [Frame #392]
Jareth
Got thru three videos today :)
Pedal Box was interfering so opened up the cut out a little.
Jareth
FIRST: Was there once a video showing how to relocate the Master Cylinder Reservoir?
SECOND: What is the best way to remove the Reservoir, it seems to be just held in place by some pins? Are they pressed fit?
Sadly It seems now that DFK is pursuing their VW Project, they won’t be adding any of the new build videos that they say are coming soon ☹️
neodied
Yes, the pins are just friction fit. I tapped them out with a matching sized punch and small hammer. Didn’t take much force.
Jareth
Thanks, Yes, I was able to sacrifice some old hex keys and use them to punch out the pins.
Jareth
Brake proportioning valve is installed, here is how I routed the lines.
Were the lines came in contact with Booster I sliced some small diameter rubber hose to prevent them from rubbing.
Jareth
WHAT THE “F” (yes those are all cap)
Just spent a hour trying to find where I put my BMC & TPMS, no where to be found.
Guess that’s what happens when parts sit around for a year.
Jareth
The box was a brown one with DFKITCAR tape on it, in the spare bedroom.
All joking aside I don’t remember which box number; this is the second Goblin I’ve built so I just went thru the boxes until I found what I was looking for.
I show the complete inventory of everything I got in the following video on YouTube.
Jareth
I think I sort of know where my BCM is? In the same box as my fuel filler neck and gas cap that I now can’t find :mad:
Just don’t understand it, I have several of those black containers with the yellow lids that you get at HomeDepot that I store everything in as I take the parts off the donor. Where is that box? :mad:
