escapepilot
- escapepilot Goblin Guru
I don’t have a recommendation on pumps, but one tip for the SS/SC is to install the heat exchanger before the radiator. It’s not mentioned in the videos, but makes it easier to install then.
Also, keep the intercooler pump in the exact same orientation or you could run into issues with the subframe. If you do choose to run the phenolic intake spacer, the intercooler hoses may (probably will) hit the fue tank so have the engine 100% ready to install before putting it in the chassis. With the supercharger on the front, there isn’t much room to do anything after it’s in.
EDIT: Leak check the intercooler system as soon as practical.
